GM, had to clean out my ATV this morn and start from scratch, anyhow I tried install Pandora this morn and suddenly geting the error, Script Failed
Can anyone help here is the log
10:19:20 T:125341696 M:108609536 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
10:19:20 T:205262848 M:109731840 DEBUG: FileManager: copy /var/mobile/script.xbmc.pandora.zip->special://home/addons/packages/script.xbmc.pandora.zip
10:19:20 T:205262848 M:109518848 DEBUG: GetZipList - Processing zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2exbmc%2epandora%2ezip/
10:19:20 T:205262848 M:109514752 DEBUG: ZipManager: not a zip file!
10:19:20 T:205262848 M:109514752 ERROR: GetDirectory - Error getting zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2exbmc%2epandora%2ezip/
10:19:20 T:205262848 M:109518848 ERROR: Package script.xbmc.pandora.zip is not a valid addon
10:19:20 T:125341696 M:109518848 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
10:19:20 T:125341696 M:111329280 DEBUG: CGUIMediaWindow::GetDirectory ()
10:19:20 T:125341696 M:111329280 DEBUG: ParentPath = []
10:19:20 T:182591488 M:111329280 DEBUG: thread start, auto delete: 0
10:19:20 T:182591488 M:111329280 DEBUG: Thread 182591488 terminating
10:19:21 T:125341696 M:111591424 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/libid3tag-arm-osx.so)
10:19:21 T:125341696 M:111591424 DEBUG: Unloading: libid3tag-arm-osx.so
10:19:21 T:125341696 M:111591424 INFO: CheckIdle - Closing session to
http://stream27c.grooveshark.com (easy=0x992c000, multi=0xafd4690)
http://stream27c.grooveshark.com (easy=0x9935000, multi=0xa4f4a00)
10:19:25 T:125341696 M:112431104 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
10:19:44 T:192114688 M:112726016 DEBUG: Thread 192114688 terminating (autodelete)
10:19:50 T:205262848 M:112730112 DEBUG: Thread 205262848 terminating (autodelete)
10:20:03 T:125341696 M:112607232 INFO: Loading skin file: FileBrowser.xml
10:20:03 T:125341696 M:112594944 DEBUG: ------ Window Init (FileBrowser.xml) ------
10:20:05 T:192114688 M:111017984 DEBUG: thread start, auto delete: 1
10:20:09 T:125341696 M:110489600 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
10:20:09 T:192114688 M:111611904 DEBUG: FileManager: copy /var/mobile/xbmc-pandora-xbmc-pandora-master.zip->special://home/addons/packages/xbmc-pandora-xbmc-pandora-master.zip
10:20:09 T:192114688 M:111329280 DEBUG: GetZipList - Processing zip://special%3a%2f%2fhome%2faddons%2fpackages%2fxbmc%2dpandora%2dxbmc%2dpandora%2dmaster%2ezip/
10:20:09 T:192114688 M:111325184 DEBUG: ZipManager: not a zip file!
10:20:09 T:192114688 M:111325184 ERROR: GetDirectory - Error getting zip://special%3a%2f%2fhome%2faddons%2fpackages%2fxbmc%2dpandora%2dxbmc%2dpandora%2dmaster%2ezip/
10:20:09 T:192114688 M:111329280 ERROR: Package xbmc-pandora-xbmc-pandora-master.zip is not a valid addon
10:20:09 T:125341696 M:111013888 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
10:20:09 T:125341696 M:110776320 DEBUG: CGUIMediaWindow::GetDirectory ()
10:20:09 T:125341696 M:110776320 DEBUG: ParentPath = []
10:20:09 T:205135872 M:110776320 DEBUG: thread start, auto delete: 0
10:20:09 T:205135872 M:110776320 DEBUG: Thread 205135872 terminating
10:20:15 T:125341696 M:111558656 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
10:20:26 T:125341696 M:111988736 DEBUG: CGUIMediaWindow::GetDirectory (addons://enabled/)
10:20:26 T:125341696 M:111988736 DEBUG: ParentPath = []
10:20:26 T:182591488 M:111988736 DEBUG: thread start, auto delete: 0
10:20:26 T:182591488 M:111988736 DEBUG: Thread 182591488 terminating
10:20:28 T:125341696 M:111280128 DEBUG: CGUIMediaWindow::GetDirectory (addons://enabled/xbmc.addon.audio)
10:20:28 T:125341696 M:111280128 DEBUG: ParentPath = [addons://enabled/]
10:20:28 T:182902784 M:111628288 DEBUG: thread start, auto delete: 0
10:20:28 T:182902784 M:111628288 DEBUG: Thread 182902784 terminating
10:20:28 T:192114688 M:110968832 DEBUG: DoWork - took 156 ms to load special://masterprofile/Thumbnails/c/cbebd8cf.jpg
10:20:29 T:125341696 M:106852352 DEBUG: CGUIMediaWindow::GetDirectory (addons://enabled/)
10:20:29 T:125341696 M:106852352 DEBUG: ParentPath = []
10:20:29 T:205135872 M:106852352 DEBUG: thread start, auto delete: 0
10:20:29 T:205135872 M:106852352 DEBUG: Thread 205135872 terminating
10:20:59 T:192114688 M:111542272 DEBUG: Thread 192114688 terminating (autodelete)
