Here is all of the fanart I've gathered for Pandora. I created the blue bokah one and the grunge one. The others are found from the net and I put Pandora Logos on them.
Dropbox Link
I am getting "Unable to load keys" error. Any suggestions?
Is it possible to do one-button access to Pandora? I have a Harmony One and would love to map this to one of the touch screen icons.
.sal
Using some skins (I use 'transparency'), you can mark the pandora add-on as a favorite and assign a custom menu item to the Pandora item. That'll get you one-click access from the home screen, but I'm not sure if that's possible to map to an action on a Harmony remote.
Strange... this has just stopped working for me today. Anyone else? Or has my setup become confused in some way?
EDIT: Output of xbmc.log here:
http://pastebin.com/zcuMFrqG
Seems to be returning a 404?? I'm using the last mod (Dixon Butz) with no changes made by myself and it worked up until yesterday...
Here is a background I like quite a bit - not of my making. I use it for my home menu for Pandora.
(2012-05-09, 19:09)mitpianoman Wrote: [ -> ]Using some skins (I use 'transparency'), you can mark the pandora add-on as a favorite and assign a custom menu item to the Pandora item. That'll get you one-click access from the home screen, but I'm not sure if that's possible to map to an action on a Harmony remote.
I'm also using Transparency, but couldn't find where you can select favorites. Is that in the menu options somewhere?
(2012-05-10, 10:37)edszfa Wrote: [ -> ]Strange... this has just stopped working for me today. Anyone else?
Just confirmed that it's functioning normally for me using your method.
Is there a way to add and search for new channels from this add-on?
Also, Is there a way to keep the INFO up for each song regardless. I have to keep hitting the INFO button on my Nyxboard in between every song.
Thanks,
JOe K.
(2012-05-10, 23:25)spalmisano Wrote: [ -> ] (2012-05-09, 19:09)mitpianoman Wrote: [ -> ]Using some skins (I use 'transparency'), you can mark the pandora add-on as a favorite and assign a custom menu item to the Pandora item. That'll get you one-click access from the home screen, but I'm not sure if that's possible to map to an action on a Harmony remote.
Go to Music then go to music addons. highlight pandora press c on your keyboard to bring up the context menu then hit add to favorites. then go to skin settings -> menu -> custom and select pandora.
(2012-05-11, 16:32)tjcinnamon Wrote: [ -> ]Is there a way to add and search for new channels from this add-on?
Thanks,
JOe K.
Anyone know if there are solutions to either of these?
