Pardon me what is VTWoods? What's the new feature about in the latest .zip?.
(2012-06-12, 02:15)Veronica Wrote: [ -> ]Pardon me what is VTWoods? What's the new feature about in the latest .zip?.
lol. VTWoods is the forum member who fixed this addon after it was broke for a few days (maybe a week).
(2012-06-10, 16:36)VTWoods Wrote: [ -> ]The addon is not written in the most robust way. If you want this addon to work with more consistency fork my code and add better data validation to the json parsing and config parsing. I am simply making everything work, but a full rewrite is needed.
I'm going to try to carve out some time to look at the data validation and parsing bits. Anywhere specific you'd suggest for a start or just overall it needs help in that dept.? I'll update if/when I fork and have something useful.
Nm, got it sorted. Issue with having an out of date xmbc. Sorry!
am i missing something?
deleted from addons menu.
deleted from /home/user/.xbmc/userdata/addon_data.
deleted from /home/user/.xbmc/addons.
rebooted
installed latest zip from this thread.
rebooted
installed
added my account info
rebooted
still getting failed to authenticate listener!!
help?
(2012-06-16, 18:56)bostoneric Wrote: [ -> ] am i missing something?
rebooted
rebooted
installed
rebooted
help?
Did you try to re-fetch keys?
(2012-06-16, 19:03)Dixon Butz Wrote: [ -> ]Did you try to re-fetch keys?
dont have that option anymore in the pandora addon settings
just usersname/pass/audio format
thanks for the help.
Oh yeah damn.
Why did you delete the folder from addon_data?
Maybe try restoring that. Keys may have been in there.
just wanted to make sure i had a clean install of latest working version.
last few versions i tried i had no luck with.
i have a bunch of old versions saved. i'll try installing an old version to see if i can pull the keys down.
then i'll try latest version.
As a test I deleted the dir from addon_data.
Re input my account and it worked. There is no keys in that dir now.
In the new version, keys are located in pandora_keys.py locally. Re-fetching is not required.
While deleting the old version, make sure to also delete the old zip from packages folder inside the addon folder. If it still does not work, post xbmc.log.
Works great for me. Thanks so much for keeping this alive. This is the single most important addon for me!
VT, Thank you so much for the fix!
