This is official CrystalHD issues report thread.
Please use latest recommended drivers at all the times and
Latest SVN nightly builds before reporting on any issues as your problem might be fixed already.
here is what is needed for the proper report:
[INDENT]1.
Full xbmc debug log
2.
Media info for the offending file
3.Describe the issue in as many details as you can
4.50-100MB file clip (optional but preferred)
[/INDENT]Before posting, look at the CrystalHD thread for the known issues, if they are there, devs know about it.
Note:
- all +1 posts will be deleted
- all incomplete reports will be deleted
- all posts from other platform specific forums will be merged here or deleted
- no discussions here, lets try and keep the thread clean and easy for devs to go trough and retrieve relevant information
- please do not paste debug logs and media info in the posts, use pastebin.com and post the link to it here
I have an AppleTV setup running Ubuntu 8.04
-Latest crystalhd r26 drivers are compiled and installed
-XBMC SVN 28078 is being used. Later builds are currently unstable.
-Full XBMC debug before crash:
http://pastebin.com/xpQqZ1uH
-Movie: This happens with all MKV files not one specific movie
-Issue I have is the following.
I can watch all movies with crystalhd card just fine. HD or SD using h264. Problem that I have having is when I skip to next chapter, fast forward in movie. AppleTV 90% of the time will reboot (Orange light on front will start blinking) then I see linux kernel booting up. I can reproduce this problem very easily. Very rare is it that I can get chapters to actually work. I have been using crystalhd for a while now and know that fast forwarding in movie has had it's issue. Issue I am posting about now may very well still be a known problem just wanted to check. Resume function seems to work just fine if I want to continue watching a movie at a later time.
Description:
When playing a MakeMKV rip of the King Arthur BD, artifacts in the video flicker in and out every 1-2 seconds. Frames are not dropping, vq and aq stay close to 99%, but never dropping below 80% for vq. I have tested both over the network and on a local drive with the same results. On a separate, more powerful machine, video plays fine. Not using the Broadcom card for rendering, the video plays without artifacts, but with frequent dropped frames due to CPU usage getting maxed out.
I have attached 2 screenshots showing with and without artifacts.
Machine:
Mac Mini 2.0 GHz (2GB RAM) - OS 10.6.3
XBMC r28256
Broadcom driver 1.0.3 (binary download and r26 compiled on 10.6, both with same results)
Pastbin info:
xbmc.log -
http://pastebin.com/ReTCd3VS
Media File -
http://pastebin.com/4SVupKYU
Also, when i pause any h264 file and then press play, the video stutters. I have to pause/play a few times or quit the video and resume it for the video to play again properly. same goes for hitting tab and switching back to the GUI and then back to the video.
Cheers!
matthoffman Wrote:I have an AppleTV setup running Ubuntu 8.04
-Full XBMC debug before crash: http://pastebin.com/xpQqZ1uH
This issue appears to be resolved. For some odd reason my MaxCPUState C2 did not take. When I tried again it took this time and these issues seemed to go away.
Hello,
I have a strange problem with CrystalHD. The problem appears suddenly. How do I run any HD movie is a failure XBMC for a while. The film does not start or displays very slowly.
I use Archlinux.
Full XBMC Log
http://pastebin.com/RfPqmTg0
Crash log
http://pastebin.com/0TCaNEG9
arteqw Wrote:Hello,
I use Archlinux.
Full XBMC Log
Crash log
Your xbmc.log show less than one second of playback before you stopped it. How can we see what's going on if you do this. Start xbmc, navigate directly to the video in question, play it and leave it playing for at least 10-15 mins, then stop and quit xbmc. Now you have a nice xbmc.log that JUST contains info regarding your issue... pastebin it.
i have mac mini 1.66, osx 10.6.3, xbmc r28256, crystal driver 1.0.3.
all mkv files play good for 1 hour. after that the movie pause and i have to stop movie. when i resume movie its play in software render. i have to load the driver again.
xbmc log:
http://pastebin.com/h43taJ21
dmesg:
http://pastebin.com/WyAKmTFs
beytarj Wrote:i have mac mini 1.66, osx 10.6.3, xbmc r28256, crystal driver 1.0.3.
xbmc log: http://pastebin.com/h43taJ21
dmesg: http://pastebin.com/WyAKmTFs
That's a new error in dmesg, have never seen that one.
I have an Apple TV which is runing 3.0.1 firmware.
I have patched with atvpatchstick ....
I have also installed the driver for BroadCom crystall HD ( 1.0.3) and the nightly build of XBMC R26768.
I can select the render method in XBMC is Broadcom Crystal HD. I have also checked XBMC.log, the status of Crystal card with dmesg command as well. Anything is seem working well but I can't watch any 1080p mkv movies ( lagged ).
Here is my XBMC.log.
http://pastebin.com/1mw7fczZ
Please help me to find out what is happening with my job.
Thanks so much
MisaVN
