Hi matt_mcmhn,
Did you happen to find a solution for your issue?
I am having the same issue!
I am using the Acer 1600 with my Vizio TV, plugin through HDMI
I have also used the steps from lifehacker
http://lifehacker.com/5391308/build-a-si...-the-cheap
And installed the OS on the tumbdrive from a CD (Using my laptop)
I have also verified that I can boot my laptop via the usb drive and can see XBMC with no issues, as well as play with the menu and view movies, but it will not work on the Acer 1600!!!
Note:
I can't copy and past the entire log as I can't read anything from my tumbdrive when I plug it into my laptop, so here is some of the logs and I hope it helps!
(II) intel (0): Not using default mode "1152x864" (exceeds panel dimensions)
(II) intel (0): Not using default mode "1680x1050" (exceeds panel dimensions)
(II) intel (0): Not using default mode "1920x1080" (monitor doesn't support reduced blanking)
all the way to
(II) intel (0): Not using default mode "2048x1536" (exceeds panel dimensions)
(II) intel(0): EDID for output TV1
(II) At translated set 2 keyboard: Close
(II) UnloadMosule: "evdev"
(II) Video Bus: Close
(II) Sleep Button: Close
(II) Dell WMI hotkeys: Close
(II) Power Button: Close
ddxSigGiveUp: Closing log
