2010-03-28, 00:10
Hi all, I have XBMC on my main TV machine, and am now trying to get it up and running on the smaller, less powerful machine in my bedroom, all installs fine, but when I try to run it I get a seg fault.
Here is my error log:
This leads me to think that it's graphics related.
Output from lspci is:
01:00.0 VGA compatible controller: Matrox Graphics, Inc. MGA G550 AGP (rev 01)
Is this card not supported?
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Mar 27 15:45:45 GMT 2010
XBMC Options:
Arch: i686
Kernel: Linux 2.6.31-14-generic #48-Ubuntu SMP Fri Oct 16 14:04:26 UTC 2009
Release:
Distributor ID: Ubuntu
Description: Ubuntu 9.10
Release: 9.10
Codename: karmic
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/dave/core
Core was generated by `/usr/share/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00369ed6 in glClearColor () from /usr/lib/libGL.so.1
Thread 1 (Thread 1369):
#1 0x08543971 in CRenderSystemGL::ResetRenderSystem(int, int, bool, float) ()
#2 0x0854a7a5 in CWinSystemX11GL::SetFullScreen(bool, RESOLUTION_INFO&, bool)
#3 0x0854762b in CWinSystemX11::CreateNewWindow(CStdStr<char> const&, bool, RESOLUTION_INFO&, bool (*)(XBMC_Event&)) ()
#4 0x0854b771 in CWinSystemX11GL::CreateNewWindow(CStdStr<char> const&, bool, RESOLUTION_INFO&, bool (*)(XBMC_Event&)) ()
#5 0x082dc974 in CApplication::Create(void*) ()
#6 0x084f7f42 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
15:45:44 T:3078354800 M:397799424 ERROR: Failed to create common scripts symlink.
15:45:44 T:3078354800 M:397705216 NOTICE: -----------------------------------------------------------------------
15:45:44 T:3078354800 M:397705216 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Dec 24 2009 (SVN:26018)
15:45:44 T:3078354800 M:397705216 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
15:45:44 T:3078354800 M:397705216 NOTICE: special://masterprofile/ is mapped to: /home/dave/.xbmc/userdata
15:45:44 T:3078354800 M:397705216 NOTICE: special://home/ is mapped to: /home/dave/.xbmc
15:45:44 T:3078354800 M:397705216 NOTICE: special://temp/ is mapped to: /home/dave/.xbmc/temp
15:45:44 T:3078354800 M:397705216 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
15:45:44 T:3078354800 M:397705216 NOTICE: Log File is located: /home/dave/.xbmc/temp/xbmc.log
15:45:44 T:3078354800 M:397340672 NOTICE: Setup SDL
15:45:44 T:3078354800 M:396365824 NOTICE: load settings...
15:45:44 T:3078354800 M:396365824 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:45:44 T:3078354800 M:396365824 NOTICE: loading special://masterprofile/guisettings.xml
15:45:44 T:3078354800 M:396406784 NOTICE: Getting hardware information now...
15:45:44 T:3078354800 M:396406784 NOTICE: Checking resolution 12
15:45:44 T:3078354800 M:396447744 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:45:44 T:3078354800 M:396447744 NOTICE: Loaded playercorefactory configuration
15:45:44 T:3078354800 M:396447744 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:45:44 T:3078354800 M:396447744 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:45:44 T:3078354800 M:396447744 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
15:45:44 T:3078354800 M:396447744 NOTICE: Default DVD Player: dvdplayer
15:45:44 T:3078354800 M:396447744 NOTICE: Default Video Player: dvdplayer
15:45:44 T:3078354800 M:396447744 NOTICE: Default Audio Player: paplayer
15:45:44 T:3078354800 M:396447744 NOTICE: special://masterprofile/sources.xml
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
