2010-03-28, 12:33
I am having a little problem:
I am trying to change a string in strings.xml, if I change it in the english version it works ok,
Example:
Change <string id="550">Sort by: %s</string> to
<string id="550">Test: %s</string>
working ok.
But when I change it in the spanish language:
<string id="550">Ordenar por: %s</string> to
It does not work, it shows all in english.
I did a solution, I change all the strings in english language to spanish and I cut modify them, no problem, so now I select english and it comes in spanish.
But I wouldlike to know why I can not modify the spanish language?
Just to know.
P.D.
I wnt to modify the string becouse "Ordenar por: %s" it shows out of the box.
Example:
working ok.
Just to know.
P.D.
