Full Version: [Release] Arkanoid pre1.0 Alpha (XBMC Game)
Category:
Scripts - Games
Version: pre-1.0 Alpha
Date: 27-03-2010
Creators: Frost
Developed: On XBMC for Windows 28202
XBMC Platform: ALL, but tested only on win32
Url: http://passion-xbmc.org
Download to : http://passion-xbmc.org/downloads/?sa=view;down=96
Description:
Replica of the famous game Arkanoid (1986) and Tournament Arkanoid (1987) ported on XBMC with a few variables
Includes 4 playing mode
- Classic Mode -> Arkanoid (1986) 32 Level, no boss "Doh" level in future
- Tournament Mode -> Tournament Arkanoid (1987) 32 Level, no boss "Doh" level in future
- Mode Custom Level -> Playing with staff levels
- Practice Mode -> Play a particular level of Arkanoid (1986) or Tournament Arkanoid (1987)
Includes a level editor, either to a full level or for edit an original level
Management scores not completed on this Alpha
Known bugs should be corrected on the next release.
- The ball can sometimes passed through a indestructible block "Gold" and stuck the other side.
the only solution for now is to leave the script and start again
- Again the ball sometimes it is bounded and turn around but the angle changes slowly and it feels it is taken,
then the only solution for the impatient like me Big Grin, is out of the script and start again
[b]Controls support:
PC:
- MOUSE:
[/b]- Move Left/Right for control vaus
- Left button = launch ball or fire
- Right button = Pause Game
- [b]KEYBOARD
[/b]- Arrows Left <-
- Arrows Right ->
- Enter for launch ball or fire
- C or Menu KEY for pause game
[b]XBOX:
- KEYBOARD/MOUSE:
[/b]- Same as PC
- [b]D-PAD:
[/b]- A = Select/launch ball/Fire
- Left <-
- Right ->
- Trigger Left/Right for control vaus
- White = pause game
And thank you to specify the exact problem you encounter while playing.
Remember, if the game run slowly, close applications that take resources from the PC. it helps
Screenshots:
http://passion-xbmc.org/fichiers_multime...77-001.jpg
http://passion-xbmc.org/fichiers_multime...20-002.jpg
http://passion-xbmc.org/fichiers_multime...238-05.jpg
http://passion-xbmc.org/fichiers_multime...963-02.jpg
http://passion-xbmc.org/fichiers_multime...140-04.jpg
Chnagelog Alpha2
- [Linux] fixed: case sensible for Vaus_lasers.gif to Vaus_Lasers.gif
- added: some settings
- added: description.xml and Gui Infos
- added: pause game
- added: reset game
- added: default skin "Confluence", but work with any skins
Cheers
Frost
Cool ! Works great...
Did run it also in MiniMeedia Waffa!
Waffa Wrote:Cool ! Works great...
yes just don't have the left colum that should appears
hi, little update alpha2
And now source is ready from SVN http://code.google.com/p/passion-xbmc/
Or use plugin SVN Repo Installer -> passion-xbmc -> scripts -> arkanoid
alpha2 changelog
Quote: - [Linux] fixed: case sensible for Vaus_lasers.gif to Vaus_Lasers.gif
- added: pause game
- added: reset game
frost
