Full Version: Eventghost not communicating with XBMC
Hi everyone
Im having problems with eventghost -> XBMC with the XBOX controller...
Everything seems to be working fine within Eventghost, task is starting up and everytime i push a button, the controls are getting recorded..
But when i fire up XBMC, nothing seems to happen? If i ALT-TAB switch task to EG, I can see this:
Task.Created.XBMC
Task.NewWindow.XBMC
Task.Deactivated.Desktop
Task.Activated.XBMC
XBCDRC.UP
XBCDRC.UP
Task.Deactivated.XBMC
Task.Activated.EventGhost
XBCDRC.UP
XBCDRC.UP
Task.Deactivated.EventGhost
Task.Activated.XBMC
XBCDRC.UP
XBCDRC.UP
XBCDRC.UP
XBCDRC.UP
XBCDRC.UP
Task.Activated.XBMC
Task.ClosedWindow.XBMC
Task.Destroyed.XBMC
Can anyone help me?
Um, just hazarding a guess here, but when you press a button in eventghost, are you having it trigger an output that xbmc will understand? For example, when you hit the up arrow on your remote is eventghost catching it and converting it to the up arrow on the keyboard?
Figured it out! I had to open the xbmc.xml file with EG, I had just added the plugins before.. Now everything works like a charm!
Thanks anyway!
