Hello all.
I'm using latest version from GIT. The application exits after the playback of a movie is finished or sometimes when its manually stopped.
I'm looking for basic help how to turn on the logging and where do I find the logs at all?
Forgot to mention that I'm on Ubuntu 9.10.
ppic,
I saw many changes related to addons, but since the official release also exited before I've tried GIT, I suspect the problem is not related to addons at all.
I hope the logs will have some hint what might be wrong with my system.
Any ideas how to get the logs?
ok !
so the log should be in /home/.xbmc/temp/xbmc.log
The log always has the following error entry when the problem appears:
ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
Any ideas what could cause that?
The exits are random, I can't find any specific flow why it happens at the end of movie playback.
See
http://pastebin.com/hcTkZamq
Check out the highlighted line 8784 at the end.
The log was taken right after the exit.
Will appreciate any help with this.
can you do it with a svn version before the merge.
Can you give instructions (command line)?
I'm using git, not svn.
well, i can't help you there, sorry
