Nice, I'll check this as soon as the XBMC-DEVS gives the 'OK' for supplying the more stable SVN-Release of XBMC, for which everybody is waiting.
However, great work !
Is there an Auto-Update feature integrated ?
you don't need to wait, it's for skins.
no auto update.
setting to switch between Stable - Svn versions
The name of the plugin can cause some confusion
yes, originaly designed for nightly but i added stable (some may not work in with stable skins because they are in rar format, i don't handle it for now)
By adding one or two capture I think it will be clear to everyone.
I will also ask one or two extra features on the original subject so that you do not get lost the rhythm and you deserve your bonus: p
About halfway through downloading Aeon65 from the program it cuts out with a script failed error, but none of the others have this. Just thought Id inform you
post your debug log, but can be a conection problem.
Hi ppic,
My guess is the pb is on the file itself, I have the exact same problem with the installer passion-XBMC
Temhil Wrote:Hi ppic,
No. I tried several times to install Aeon65 and I have not encountered any problem with this plugin.
With the Installer V2-Passion download works but decompressing the archive does not occur. I'll post you a log.
This skin is compiled by the server as the others. The only difference I see is that it is the largest file.
Fixed for the plugin. For now if the download take less than fifteen minutes it should work.
This will be improved soon and there will be no time limit. ( Apache and Php improvement, all problem on the server side ).
For the Installer-Passion V2, it will be fixed after the next Aeon65 compilation. (vrong archive size in the Download Center).
