2010-04-05, 21:12
Hi folks,
before post this 3d I've read all (I think) the other solution in the other 3d
F.E. I had done this:
without success. The command shutdown isn't show in the menu (option menu, in alaska skin) and if I try to do it with another skin, I'm redirect to the console.
SVN r28256
Quote:sudo apt-get install policykit-1 devicekit-power
sudo nano /var/lib/polkit-1/localauthority/50-local.d/custom-actions.pkla
add:
[Actions for xbmc user]
Identity=unix-user:xbmc
Action=org.freedesktop.devicekit.disks.*;org.freed esktop.devicekit.power.*;org.freedesktop.consoleki t.system.*;org.freedesktop.hal.storage.mount-removable;org.freedesktop.hal.device.volume
ResultActive=yes
ResultAny=auth_admin
ResultInactive=yes
SVN r28256
