Full Version: XBMC showing wrong ip
I can not get XBMC (latest 9.11 release) to match the same ip as the PC it is installed on. My machine's ip is 192.168.1.3 but, XBMC is showing my ip as 192.168.53.157. I have no idea where it is getting this address from and I can not find a way to edit it. Thanks for any light you can shed on my problem.
Open a command prompt and run the command ipconfig and see what IP addresses your PC has.
JR
Thank you!
Turned out my OCUR was causing the problem. I just made my PC's connection priority and the problem was solved.
