When I add a new movie To the movies folder xbmc Download movie information I see the movie in new movie
But not with All the movies
I Re-installed the software several times but it not helped
How can I fix it
Thanks for the help Lior
Switch to a supported skin (and go easy on the submit button).
I use this skin Transparency!_v2.11
Or whatever, just switch to a supported skin or take this to the Transparency subforum.
Then answer my original question "What are your watched settings like?".
Switch skins on the first screen. Before you do that I am unable to help.
Liord - at least carry out sho's basic instruction to enable him to help you, don't just give information that you think might be relevant.
Firstly switch to the default 'confluence' skin - in your first screenshot - first entry 'skin', to the right scroll through options, You've got 7 (Seven Skins?) of them, scroll through until you get to Confluence then once in Movie Library, either use left control on remote, or move your mouse to the far left of the screen to gain access to the hidden menu from there choose Misc.Options and ensure that Hide Watched is not checked.
First lesson in getting help follow instructions - it can get very infuriating, when it appears that instructions are just being ignored.
sho Wrote:Switch skins on the first screen. Before you do that I am unable to help.
I Switch skins on to first screen Confluence
liord10 Wrote:I Switch skins on to first screen Confluence
Did you then check whether Hide Watched was checked or unchecked, as per my last post - c'mon mate we're really trying to help, but your making it very difficult
