Full Version: "Rotating" an image..Help!
Nevermind! Sorry.
Glad you got it sorted. It'd be helpful if you posted the solution to your problem. This then increases the signal:noise ratio, making it easier for others. Smile
Cheers,
Jonathan
jmarshall Wrote:Glad you got it sorted. It'd be helpful if you posted the solution to your problem. This then increases the signal:noise ratio, making it easier for others. Smile
Cheers,
Jonathan
I would but it was so dumb I would be ashamed.
Long story short, I forgot "rotate" was an option, only tried rotatex and rotatey. Huh
