Quote:sudo apt-get remove xbmc-live
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package xbmc-live is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Quote:sudo nvidia-installer --update -a -s -f
Verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86 190.53............................................................................................................................................................................................................................................................................................................
ERROR: Unable to open '/usr/lib/nvidia/libglx.so.xserver-xorg-core' for reading
(No such file or directory)
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xbmc-live: Depends: xbmc-standalone (= 1:9.11+svn28256-jaunty1) but it is not going to be installed
E: Broken packages
not working yet, any other ideas?
