Full Version: xbmc lyrics - what does it do, anyway?
hi,
im using an xbox with the latest bleeding edge tech xbmc build. i have always had xbmc lyrics but it has never done anything for me.
can someone tell me what this script is *supposed* to do, and how i am supposed to properly use it?
thanks!
it displays the lyrics to a song while it is played via xbmc.
but "xbmc lyrics" is outdated, there is a new script called "CU lyrics" (search forum).
thank you. it has never done anything for me, so hopefully CU Lyrics will work out of the box.
do you know if it works on the xbox port of xbmc? i guess ill find out.
