Full Version: [XBOX] Any way to assign Fan Speeds to a button?
I don't know if this is possible since the Xbox version of XBMC is no longer under development, but since the fan speed can be changed in the system settings is there a way to use a XML file to trigger the fan speed up and down? Or perhaps a Python script?
i dont know if this will help or not.i was looking at confluence to see if id like it...but there is a option under skin settings,that allows you to assign custom scripts to a single button..you may be able to use that to accomplish what you want or see if someone can help you modify it for yoour needs
sorry zack ...it was media stream redux...the two look so much alike!!
Ah I'd have to use a Python script. How hard can it be? Wink
