Full Version: CSI wont scrape properly
my log is at http://pastebin.com/E5EPkBNn
I cant seem to get CSI (las vegas) to scrape properly it always comes up as CSI:NY even after I used media companion and scraped it properly with that any help would be great. as well as the movie the Girl next door, I think there should be a way to select the proper tv/movie while scraping
Split2ooo Wrote:my log is at http://pastebin.com/E5EPkBNn
Firstly to achieve flawless scraping, you have to make sure the name of the show matches exactly the tvdb entry, if that is the scraper you are using - in the case of CSI (that's not its title on thetvdb it is CSI: Crime Scene Investigation). You'll need to rename, drop the colon and replace with a space like this CSI Crime Scene Investigation and it will scrape fine.
