2010-04-11, 13:27
Hi
I have an XUBUNTU running XBMC 9.04.1 r20654.I also have an XBOX usb remote whicj lsusb reports as
And command cat /proc/bus/input/devices gives
When running XBMC i get an popup inside xbmc saying
However, the system does not respond to any of the commands from the remote with Keymap.xml unchanged from original. I have a test equipment at home testing if the remote controller is working and the remote is sending IR commands as it should.
I guessed the Keymap.xml needs to be altered, and for a long shot I simply changed the setting for joystick name "Microsoft Xbox Controller S" to "Generic X-Box pad".Offcourse that did not worke correctly having one command from my remote making the xbmc going cracy. (I pushed DOWN arrow once and that maked it beleive the DOWN signal (or wathever) was constantly pressed until I unplugged the USB remote receiver).
Problem is that I have not found any way to detect within Linux WHICH command is sent from the remote at every press and thus I can not make a Keymap that fit my remote. If any have the same remote I would be very happy if you could provide me a copy of your Keymap,or tell me how to gain the code sent to make my own keymap.
I could offcourse hook up an oscilloscope, but that is pretty timeconsuming trying to fetch correct values by analysing the IR pattern. Not to talk aboute my ten thumbs.
Thanks in advance
Quote:Bus 004 Device 002: ID 045e:0284 Microsoft Corp. Xbox DVD Playback Kit
Quote:I: Bus=0003 Vendor=045e Product=0284 Version=0130
N: Name="Generic X-Box pad"
P: Phys=usb-0000:00:1d.2-2/input0
S: Sysfs=/devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input6
U: Uniq=
H: Handlers=event5 js0
B: EV=b
B: KEY=683f0000 400000 0 0 0 0 0 0 0 0
B: ABS=3003f
Thanks in advance
