2010-04-11, 14:08
first of all, THX for such a great Software! i love it.
So here is my Problem. I am using a Zotac ION Board and the wireless Connection is working from the console.
On the console i can ping to my PC and i also can make a ping to www.google.de. So i think all seems to be ok with the wireless conn.
But xbmc don't use it. I can not see the weather information nor the scrapers can connect to the internet.
With the LAN Connection it works. So what can i do that xbmc also use wlan0 for the internet?
eth0 -> all functions are ok (wired conn.)
wlan0 -> ssh to and from the box - ok
-> ping from console to www.google.de - ok
-> xbmc scrapers or weather or any other internet/lan conn - not ok
Within xbmc the information Tab show me the ip and all seems to be ok.
The Proxy is disabled.
Sorry for my bad english
Thx for your help,
Eleas
Thx for your help,
Eleas
