Full Version: Weather problem
Hi!
I`m having problems with the weather page.
Some of the text is on top of the other text.
I`m using Norwegian lanuage.
it's due to some recent changes in xbmc.
you'll need an updated version of Transparency! if you are using svn versions of xbmc.
http://forum.xbmc.org/showpost.php?p=506601&postcount=1
Tested with the latest T ver.
One other problem, the "High" and "low" text (temp) doesn`t translate to Norwegian.
All other text is translated.
not a skin issue.
those labels were added to xbmc in r27712.
guess nobody updated the Norwegian xbmc language file.
String 418, 419 was missing in the Norwegian language fileSmile
what is a svn-version of the skin vs the skin i download directly from xbmc.org?
twinflower Wrote:what is a svn-version of the skin vs the skin i download directly from xbmc.org?
the skin on xbmc.org is T! v2.11 and could be considered svn r0
the skin on google-code is currently at svn r311
in other words, 311 fixes/changes/features have been added since T! 2.11
ronie Wrote:the skin on xbmc.org is T! v2.11 and could be considered svn r0
Thanks for clarifying.
I guess I should download r311 then.
twinflower Wrote:Thanks for clarifying.
if you want to user the latest T! svn, be aware you'll also need the latest available xbmc svn, which is still considered unstable.
Ronie: that link you provided me with to get the SVN transparency for win32 says its version is v2.16 (SVN) i take it this is not the latest?
If thats the case there must be a way to getit using windows no?
Its cool ronie got tortoise i should do a bit more reading before i ask Big Grin
