The way we were talking it was only one logo per series.
This could change depending on how the development of the new site goes however...
For the time being lets just assume the former case.
Downloaded my revision of Night last night (no pun intended) Also, you're totally right, that's an excellent version! Thanks!
(It's odd though, that version doesn't show in the directory listing...
http://www.themurrayworld.com/xbmc/logos/)
I may need to update my XBMC version, but I didn't think that should affect this.
--FF
Huh? malcolminthemiddle is named right on the site, when I tested on a few logos - pushing daisies and southpark which have alternates it downloaded the correct one. I'll 2x check...
He also updated the script so it can run from dialogvideoinfo and it behaves like "Get Fanart" button does and you can pick logos one by one but I haven't had time to play with it yet...
"thetvdb.com ID is cut off in the file name, so remember to rename it. I blame imageshack..."
Yea I've noticed that since we adopted the naming scheme with imageshack, no biggie I catch them...
Nice logo with such a bad source
mcborzu Wrote:"thetvdb.com ID is cut off in the file name, so remember to rename it. I blame imageshack..."
Thanks, that was the best source I could find without recreating it myself
wow... I feel stupid, I forgot the Directory listing differentiates between upper and lowercase, that's why I didn't see it there...
Thanks again,
--FF
Fist of the North Star
Not really happy with the result...
I believe
Battle of the Planets is the same as
Gatchaman. Those more knowledgeable can correct me. Here's two logos to choose from.
Okay so they are apparently the same show, just
Gatchaman is the original Japanese airing and
Battle of the Planets was the inferior United States import re-airing. There's also the re-reairing called
G-Force that I'll make up a logo too. Ugh...
This one is for
Mazinga Z, also known as
Mazinger Z.
How to change logos?
I tried to replace one logo with a fixed one. so i deleted the logo.png and replace it with new.
XBMC won't show any logo now there not the old and not new one.
I chacked xbmc.log and found this:
ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/4/4ce62d7d.png
So now I replace this file with the new logo keeping the name 4ce62d7d.png.
Now it's working and new logo appeared.
Do I really have to do all this just to replace a logo?
psike Wrote:How to change logos?
Unfortunately, it looks like you might have to. At least until they get the image caching under control. It's a real pain in the ass if, like you, the user decides to change an image. I know it's to speed up things and pull images only when absolutely necessary but still...
And now back to the logos...
I redid the logo for
Flight of the Conchords. The one in the database was a big jagged and was missing a drop shadow.
It would seem Imageshack is editing the file names even more now...I'll definitely be looking into finding a new place to host them.
