mcborzu Wrote:Nice touch on the instructions, might be good to also add:
Definitely the drop shadow one is an important one, When I made mods for Xpirence and Focus the logos I had that didn't have a drop shadow just looked flat and lifeless...
Done. The search bar now works as well, if you type in say "chuck" you get 1 result, "the air" gets 3 results, i just need to tidy it up a bit and make it look a bit nicer, i'm also going to look at if it doesnt bring any matches back querying thetvdb for matching series, returning all the results and have a button next to each so the user can add it to the request list, im not sure if thats possible though, i need to look at the API documentation.
*edit* Also if a user is logged in when they upload an image, their user id is attributed to the image, that means when i put the code in, when an image is approved/denied they can be notified.
Potentially you could do search by user to get a particular uploaders contributions, but there are 1300 images with no attribution at the moment, and theres no easy way to assign them, so its probably not very useful. Unless someone want to go through them and assign them, in which case i could create a page for mods where they can see all the images and mark their ones as theirs. What do you think? Basically it would be a long page with all the images, with a check box next to it, you check all the ones that are yours, then at the bottom theres a button to apply, once an image is assigned it drops out the list.
That definitely sounds like a great idea mate. I have a few ideas myself but need to flesh them out a bit more so they'll make sense. It's mostly to do with the way we add / remove images and the jarring that occurs when you go to add a new image and then have to click the pending section to accept it. It would be great if we could do all of that in one shot. This would be usable mostly for McBorzu and myself or anyone that has approval permissions.
Kode Wrote:Potentially you could do search by user to get a particular uploaders contributions, but there are 1300 images with no attribution at the moment, and theres no easy way to assign them, so its probably not very useful. Unless someone want to go through them and assign them, in which case i could create a page for mods where they can see all the images and mark their ones as theirs. What do you think? Basically it would be a long page with all the images, with a check box next to it, you check all the ones that are yours, then at the bottom theres a button to apply, once an image is assigned it drops out the list.
That sounds fine. I'm up for taking a few minutes and going through the list.
ahh, that reminds me, i planned that when a mod uploaded an image it was immediately approved, thanks for reminding me
*edit* Ok, when a mod uploads, it should now be approved immediately, if someone wants to test it for me i'd be grateful
I made a quick alternate for "psych" everything seemed to go as planned
ok, try
http://www.lockstockmods.net/logos/mod_check.php
Just do a couple for now, once you have clicked the "Mine" button, scroll all the way to the bottom and you should see something like:
Array
[logo] => Array
[0] => 2
[1] => 3
[2] => 1462
[Submit] => Mine
Paste it in here and i'll check that its worked properly, then you can do them all. While in test phase its only outputting 10 images at a time, once confirmed working it will output them all.
I checked two that were mine, well one was and the other I didn't make, just testing...
this was at the bottom:
Quote:Array
[logo] => Array
[0] => 12
[Submit] => Mine
hmm, thats weird if you checked 2 then 2 should have been in that array, not just one...
are these the 2 you checked?
7Days-74540.png and 30rock-79488-2.png also, which wasn't yours? i need to set it back, lol
7days isn't mine
I checked 30 rock first then clicked mine, then I clicked 7 days then clicked mine...
I didn't check both then click mine, I did it separately...
ahhh, thats fine then
you should be able to select multiple images though
i've set 7 days back, also i noticed a problem with the mod upload, its not renaming the file, so its still got the random name, it should be fixed now, can you try uploading something again, i will delete your last image
Array
[logo] => Array
[0] => 2
[1] => 5
[2] => 7
[3] => 9
[Submit] => Mine
Everything seems be working here too. Are more than 10 supposed to show though?
more than 10 should show now, i just wanted confirmation it was working
Kode Wrote:more than 10 should show now, i just wanted confirmation it was working
I tried to get as many as I could remember off the top of my head. I'll go back and have another look at it later.
Array
[logo] => Array
[0] => 19
[1] => 22
[2] => 31
[3] => 42
[4] => 48
[5] => 49
[6] => 55
[7] => 64
[8] => 65
[9] => 68
[10] => 1548
[11] => 73
[12] => 81
[13] => 90
[14] => 94
[15] => 99
[16] => 102
[17] => 103
[18] => 117
[19] => 121
[20] => 123
[21] => 124
[22] => 125
[23] => 131
[24] => 138
[25] => 144
[26] => 145
[27] => 148
[28] => 157
[29] => 162
[30] => 165
[31] => 169
[32] => 171
[33] => 173
[34] => 1542
[35] => 1545
[36] => 187
[37] => 194
[38] => 195
[39] => 196
[40] => 198
[41] => 200
[42] => 201
[43] => 204
[44] => 215
[45] => 216
[46] => 217
[47] => 225
[48] => 233
[49] => 235
[50] => 243
[51] => 251
[52] => 252
[53] => 253
[54] => 255
[55] => 270
[56] => 273
[57] => 274
[58] => 275
[59] => 280
[60] => 283
[61] => 291
[62] => 292
[63] => 296
[64] => 303
[65] => 305
[66] => 306
[67] => 313
[68] => 316
[69] => 325
[70] => 330
[71] => 336
[72] => 342
[73] => 344
[74] => 346
[75] => 347
[76] => 352
[77] => 359
[78] => 363
[79] => 366
[80] => 369
[81] => 375
[82] => 383
[83] => 384
[84] => 386
[85] => 390
[86] => 394
[87] => 403
[88] => 408
[89] => 1414
[90] => 1412
[91] => 420
[92] => 428
[93] => 429
[94] => 430
[95] => 433
[96] => 436
[97] => 440
[98] => 443
[99] => 444
[100] => 445
[101] => 453
[102] => 455
[103] => 457
[104] => 458
[105] => 459
[106] => 460
[107] => 1454
[108] => 484
[109] => 1410
[110] => 499
[111] => 512
[112] => 519
[113] => 520
[114] => 522
[115] => 528
[116] => 529
[117] => 530
[118] => 533
[119] => 534
[120] => 542
[121] => 543
[122] => 544
[123] => 545
[124] => 564
[125] => 565
[126] => 579
[127] => 580
[128] => 581
[129] => 592
[130] => 594
[131] => 597
[132] => 598
[133] => 601
[134] => 605
[135] => 606
[136] => 609
[137] => 611
[138] => 1450
[139] => 613
[140] => 622
[141] => 629
[142] => 631
[143] => 639
[144] => 640
[145] => 641
[146] => 642
[147] => 643
[148] => 644
[149] => 651
[150] => 669
[151] => 671
[152] => 674
[153] => 680
[154] => 681
[155] => 683
[156] => 692
[157] => 697
[158] => 699
[159] => 701
[160] => 702
[161] => 703
[162] => 706
[163] => 707
[164] => 724
[165] => 726
[166] => 727
[167] => 732
[168] => 737
[169] => 743
[170] => 746
[171] => 748
[172] => 749
[173] => 750
[174] => 762
[175] => 764
[176] => 765
[177] => 769
[178] => 778
[179] => 786
[180] => 788
[181] => 789
[182] => 792
[183] => 794
[184] => 797
[185] => 799
[186] => 802
[187] => 804
[188] => 808
[189] => 809
[190] => 810
[191] => 812
[192] => 816
[193] => 819
[194] => 829
[195] => 834
[196] => 840
[197] => 842
[198] => 849
[199] => 851
[200] => 854
[201] => 855
[202] => 1408
[203] => 862
[204] => 863
[205] => 865
[206] => 866
[207] => 873
[208] => 874
[209] => 876
[210] => 877
[211] => 880
[212] => 882
[213] => 895
[214] => 897
[215] => 911
[216] => 913
[217] => 914
[218] => 1407
[219] => 925
[220] => 1449
[221] => 941
[222] => 942
[223] => 952
[224] => 961
[225] => 974
[226] => 975
[227] => 976
[228] => 977
[229] => 979
[230] => 983
[231] => 985
[232] => 991
[233] => 993
[234] => 994
[235] => 995
[236] => 1012
[237] => 1018
[238] => 1020
[239] => 1021
[240] => 1025
[241] => 1027
[242] => 1028
[243] => 1033
[244] => 1035
[245] => 1036
[246] => 1037
[247] => 1043
[248] => 1046
[249] => 1054
[250] => 1056
[251] => 1058
[252] => 1061
[253] => 1064
[254] => 1066
[255] => 1072
[256] => 1077
[257] => 1083
[258] => 1084
[259] => 1087
[260] => 1089
[261] => 1093
[262] => 1095
[263] => 1100
[264] => 1102
[265] => 1104
[266] => 1105
[267] => 1106
[268] => 1107
[269] => 1115
[270] => 1405
[271] => 1119
[272] => 1121
[273] => 1122
[274] => 1124
[275] => 1126
[276] => 1129
[277] => 1130
[278] => 1132
[279] => 1133
[280] => 1136
[281] => 1137
[282] => 1142
[283] => 1152
[284] => 1153
[285] => 1154
[286] => 1155
[287] => 1162
[288] => 1163
[289] => 1166
[290] => 1176
[291] => 1177
[292] => 1183
[293] => 1185
[294] => 1461
[295] => 1198
[296] => 1199
yeah, i saw you tagged about 400
I probably did more but people fixed some of my earlier ones so I couldn't remember which ones are mine anymore
Pastebin
