Full Version: [Live] Can you share from a XBMC Live machine?
I am going to be starting a new build for my TV-only HTPC, and one of the requirements of this setup is to be able to share (smb, other) from one XMBC source to another.
Can this happen? Do I need to forgo XMBC Live and jump into a Ubuntu + XMBC install instead?
xbmc to xbmc (live or linux on both sides) ... you should use NFS.
complete instructions for server & client side setup are on the ubuntu wiki
https://help.ubuntu.com/community/SettingUpNFSHowTo
if there's a windows box in the mix then you you'll need to go the SMB route
(again) complete instructions for both sides are on the ubuntu wiki
if you want to use NFS & have an XP box -- the linux-toolkit is an option
these instructions look pretty old, but still good ( & again) in the Ubuntu community NerdBig Grin
http://ubuntuforums.org/showthread.php?t=310168
good luck
