2010-04-13, 04:23
I am having troubles trying to get audio working via HDMI using NVidia ECS 210. I have followed the wiki article and all seems to be correctly set but still no audio.
/etc/modprobe.d/sound.conf
/etc/asound.conf
When trying to test no errors are reported:
Alsamixer setting
Any help to resolve this issue would be appreciated.
htpc@htpc-xbmc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
Subdevices: 1/1
Subdevice #0: subdevice #0
options snd-hda-intel enable_msi=0 probe_mask=0xfff2
/etc/asound.conf
pcm.!default hdmi:NVidia
pcm:iec958 hdmi:NVidia
htpc@htpc-xbmc:~$ groups
htpc adm dialout cdrom audio video plugdev lpadmin admin sambashare
htpc@htpc-xbmc:~$ aplay -D plughw:0,3 /usr/share/sounds/alsa/Noise.wav
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
htpc@htpc-xbmc:~$ speaker-test -Dhdmi -c6
speaker-test 1.0.22
Playback device is hdmi
Stream parameters are 48000Hz, S16_LE, 6 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 5440
Period size range from 32 to 2720
Using max buffer size 5440
Periods = 4
was set period_size = 1088
was set buffer_size = 5440
0 - Front Left
4 - Centre
1 - Front Right
3 - Rear Right
2 - Rear Left
5 - LFE
Time per period = 17.863270
0 - Front Left
Alsamixer setting
┌───────────────────────────── AlsaMixer v1.0.22 ─
│ Card: HDA NVidia F1: Help
│ Chip: Nvidia GT21x HDMI F2: System information
│ View: F3:[Playback] F4: Capture F5: All F6: Select sound card
│ Item: S/PDIF Esc: Exit
│ │OO│
│ < S/PDIF >
