Full Version: Remote worked in XBMCLive...
So I installed XBMC Live to an external HD, to test it out. It worked perfectly, but I want to use it on a more full featured system.
So right now, I have an Acer R1600, with Ubuntu 9.10 installed. Everything is working, overscan fixed, audio via HDMI is fine - everything but the remote.
The remote worked perfectly in XBMCLive, but now does not work in Ubuntu, then running XBMC.
Using the AVS Gear HA-IR01SV, as many probably are. Is there a particular reason it works just fine on XBMCLive, but not on a full system (for lack of a better description)?
Can I just copy some particular directories from my external drive onto my current Ubuntu install?
For further clarification - XBMCLive is installed/working on an external hard drive. Ubuntu is installed on the Revo. Can I copy the lirc files, or some XBMCLive system files from the external to the Revo?
start by installing lirc. Many remotes works fine in xbmc without any tweaking.
vikjon0 Wrote:start by installing lirc. Many remotes works fine in xbmc without any tweaking.
lirc is installed, which is why I don't know why it isn't working by default like it did in XBMCLive. Sad
