2010-04-14, 20:26
Has faced a problem of a conclusion of a sound through HDMI on a parent payment
zotac gf9300-g-e.
Situation following:
Output: Digital
AC3: Off
DTS: Off
Audio Output: hdmi
Passthrough: hdmi
Downmix: On
The sound works
Output: Digital
AC3: On
DTS: On
Audio Output: hdmi
Passthrough: hdmi
Downmix: Off
Instead of sound AC3 and DTS rumbling
Thus if to make iecset-n1 audio off
AC3 And DTS the sound is deduced normally
Such impression is made that xbmc not correctly changes bit responsible for stream contents through hdmi
AC3/DTS
iecset -n0
Mode: consumer
Data: non-audio
Rate: 48000 Hz
Copyright: permitted
Emphasis: none
Category: PCM coder
Original: original
Clock: 1000 ppm
iecset -n1
Mode: consumer
Data: audio
Rate: 44100 Hz
Emphasis: none
Category: general
Original: 1st generation
Clock: 1000 ppm
analog
iecset -n0
Mode: consumer
Data: audio
Rate: 48000 Hz
Emphasis: none
Category: PCM coder
Original: original
Clock: 1000 ppm
iecset -n1
Mode: consumer
Data: audio
Rate: 44100 Hz
Emphasis: none
Category: general
Clock: 1000 ppm
xbmc switches not that device in a mode of a conclusion of the data
How to overcome this problem? Prompt how to solve a problem, in advance thanks please.
aplay l
l: No such file or directory
root@htpc:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC662 Analog [ALC662 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: ALC662 Digital [ALC662 Digital]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
Subdevices: 0/1
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=NVidia
HDA NVidia, ALC662 Analog
Default Audio Device
front:CARD=NVidia,DEV=0
Front speakers
surround40:CARD=NVidia,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=NVidia,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=NVidia,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=NVidia,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=NVidia,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=NVidia,DEV=0
HDA NVidia, ALC662 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, NVIDIA HDMI
HDMI Audio Output
Linux htpc 2.6.31-20-generic #58-Ubuntu SMP Fri Mar 12 04:38:19 UTC 2010 x86_64 GNU/Linux
alsa-driver-1.0.22.1
xbmc PRE-10.5 r28256
zotac gf9300-g-e.
Output: Digital
AC3: Off
DTS: Off
Audio Output: hdmi
Passthrough: hdmi
Downmix: On
The sound works
Output: Digital
AC3: On
DTS: On
Audio Output: hdmi
Passthrough: hdmi
Downmix: Off
AC3/DTS
iecset -n0
Mode: consumer
Data: non-audio
Rate: 48000 Hz
Emphasis: none
Category: PCM coder
Original: original
Clock: 1000 ppm
iecset -n1
Mode: consumer
Data: audio
Rate: 44100 Hz
Emphasis: none
Category: general
Clock: 1000 ppm
analog
iecset -n0
Mode: consumer
Data: audio
Rate: 48000 Hz
Emphasis: none
Category: PCM coder
Original: original
Clock: 1000 ppm
iecset -n1
Mode: consumer
Data: audio
Rate: 44100 Hz
Emphasis: none
Category: general
Clock: 1000 ppm
aplay l
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 0/1
aplay -L
null
default:CARD=NVidia
Front speakers
HDMI Audio Output
