Full Version: Skipping Folder-Selection...
Hi!
I am using the Confluence skin. When I choose Videos, Music or TV-Shows in the main menu, a page opens where I have to choose the smb-location (directory) where all my files are stored. Afterwards the content is shown.
Is there a way to link directly to the content from the main menu? I have only one directoy in every section so there is no need for me to choose the location, so I would like to skip this step.
Which link do I have to add to Home.xml in the item-fields of the menu?
Kind regards and thanks in advance!
See the context menu - you want "Set Default" on the folder you want to be the default.
Cheers,
Jonathan
Thank you, it works except for the picture-folder.
