2010-04-15, 21:20
Hey all,
Long time XBMC for Windows user, first time live user.
I recently bought a Zotec A-U board (the one with the Wifi Daughter Card) and installed XBMC to a USB stick using the live CD iso and off I went!
I modified my /etc/network/interfaces and did an iwconfig to bring up the wifi and it worked (to my surprise). XBMC was easily able to connect over WIFI to my SMB shares and stream content.
But what I found was, it didn't last long. After a few minutes of heavy traffic the box would drop off the network. Damn, so close... I repeated this a few times and it kept happening. I'm pretty sure the router isn't the cause since it manages to maintain a connection with my desktop, 3 laptops and 2 iphones and a wii without a problem. (None of which were file sharing during this test to rule out a bogged down network)
I tried the customized live CD iso from xbmcfreaks, specifically modified for zotec board with nvidia chipsets, but... same issue.
So I decided to see if the system could maintain a network connection. I pinged the box for what seemed like infinity from another system, and it stayed up. The minute I tried any bandwidth intensive tasks it crapped out.
Anyone else on the board have similar experiences, and if so, did you find a work around? I'd hate to have to hard wire in this box as I specifically bought it so I could use the wifi.
