Full Version: Bugs/features?
Been using this remote on my Nexus One for almost a week now and I am truly impressed with the program.
Some bugs still exist though;
When tilting phone in remote-mode the buttons get all screwed up.
Clearly not made for the 800x480 screen.
Tilting phone in music-library mode all albums or artists reload before showing.
In the music library i get the Genre: Karaoke, but when clicked there are no albums or songs showing.
Get "No movies found" in movie-library even if librarymode works on xbox.
For some reason I have 20 movie genres showing, but if I press one of the i get the "SORRY!! Application XBMC Remote (process org.xbmc.android.remote) suddenly stopped. Try again."
And a new feature or enhancment;
Sort albums by year. This is my favorite sorting and it's not there Sad
All bugs found on remote4xbmc 0.6.7 on a Nexus One and XBMC 9.04.1 r20848 on a XBOX 1.2. (All builds after this have the insane directionpad bug with skipping. The problems can very well lie here.
zephyr Wrote:Been using this remote on my Nexus One for almost a week now and I am truly impressed with the program.
Thanks Smile
Quote:When tilting phone in remote-mode the buttons get all screwed up.
Known and fixed in the next version.
Quote:Tilting phone in music-library mode all albums or artists reload before showing.
Known.
Quote:Get "No movies found" in movie-library even if librarymode works on xbox.
Yeah there is a view we query missing in the 9.04 xbox database...
I compiled the r582 and the new looks for the tilted remote is very good Nod
However I got a new problem. It wont connect to the XBMC, but I can still use the remote. The directional bug was also still there so don't know if I messed up something or what.
EDIT: Using the T3CH XBMC 2010-03-10 SVN rev2847 on XBOX
SVN version is very unstable right now. You should stick with the release and not tilt the remote for now Wink
Also running this on a nexus one, latest stable release.
I would like to see a way to lower the sensitivity on the trackball. it is much too sensitive for practical use. Either an option to adjust or lowering it to a user friendly level would be helpful.
Already fixed in the next version.
Just got my nexus as well. What a great app
Is audio playlists and smartplaylists on the to do list?
Top 100 and partymode would be great Smile
Thanks!!!
Loto: Explain.
If you compare music library in xbmc your missing top 100 and playlists
I tries to work around by opening the xps playlists in files but it returns ' not a directory '
I can't find a way to trigger partymode either
Xps files aka smart playlists should be able to open as a directory and in the context menu have a special option 'play in partymode'
