2010-04-16, 20:46
I have Xbmc Running on my PC Setup with Video Cards (4 displays) i have no problems running all 4 displays in windows but i cant seem to get xbmc to start full screen on my TV.
In the xbmc options i cant even select that display only the two displays from my primary video card show up. when i disable the display 1 and 2 then it works.
My monitors/cards are setup like so
Nvidia 8600 gt
Monitor id 3 primary windows desktop 22" monitor
Monitor id 4 secondary display HDTV via component.
Ati onboard
Monitor id 1 A 22" Monitor
Monitor id 2 15 inch monitor (Between my 22" monitors)
(notice the monitor ids)
I have to use the nvidia card for the TV because it has the component outputs.
Also i use PC for gaming so i want to keep it as my primary windows display.
Is there a way to change the monitor ids in windows so XBMC can detect my nvidia card for a full screen image? If not is there something i'm missing because I've been failing at this forever.
Nvidia 8600 gt
Ati onboard
