Full Version: [Release] port.hu Hungarian movie scraper
Pages: 1 2
Finally I put this together.
Maybe not always with the nicest/most optimal expressions, but forgive me for this, as I am neither a dev, nor a regex specialist.
It seems to working great at least.
http://code.google.com/p/xbmchuscraper/
@spiff
I would trac this (I am also holding the permission from the site editors), but I suspect, that I should trac the scraper in the new format.
I have the following questions concerning that:
- Shall the description written in English or this can be in the scraper's language?
- I am a bit confused about the scraper logo. There is a default.tbn next to all scrapers in addons folder in SVN, but in the scraper.xml the logo is linked differently. Like the imdb one. There is a default.tbn in the scraper folder, but in the xml, it's imdb.png which I can't even find anywhere. So how is the logo should named and placed?
default.tbn is the new wine. description ideally should be translatable, but until then, please keep it in english.
Great work ! Smile
Thanks for the time and work.
Working really nicely. Should be in the trunk !
it won't be Smile
scrapers won't be hosted in trunk any longer once we have the addons framework setup.
spiff Wrote:it won't be Smile
Thanks for the info.
I think it is a good idea as the scrapers can be updated in between the stable releases.
Will this framework be up until the next stable release ?
Is this also mean that there is no reason to trac it and there will be some kind of upload interface in the new addons manager?
for starters i think we'll setup a separate trac or the likes for simplicity, then make it "better" later. yes, it should be included in the next stable.
Okay, thanks spiff!
hi,
first of all great scraper!
One feature request if you don't mind. Some of the films on port.hu does not contain plot description, thus the scraper nulls it out in xbmc db.
e.g.
http://port.hu/30_days_of_night/pls/fi/f...topic_id=2
In these particular cases, would be possible to fall-back to description of imdb.com? THanks in advance. Köszi.
sircube
sircube Wrote:hi,
e.g.
sircube
I'd support this, too!
attilag78 Wrote:I'd support this, too!
How would you support it? Just curious... Cool
BTW it's implemented in scraper v1.4.1 ~11 days ago following the original request by sircube. Is there something wrong with it?
olympia Wrote:How would you support it? Just curious... Cool
I supported the idea Smile
oh, I did notice that the addon was updated, now that you say, shame on me. Since that I haven't scraped any movies with the scraper but will rescan couple others to see it working.
Marked as broken? why?
update to v1.7.2
Szia Bence,
with recent 1.9 version (I believe the latest one),
the certification (MPAA rating or similar) is not scraped, in case the addon is configured as Hungarian Certification = DISABLED.
Aeon Nox shows not rated. (have not checked the database yet)
Any hint guess for the reason?
keep up the good work!
-sircube
Pages: 1 2
