2010-04-19, 06:32
Hi!
Have a very annoying problem, my Asrock 330 with a Microsoft MCE remote is immediately waking after suspend.
Have checked my grub for the "usbcore.autosuspend=-1", and as far as I can see, it is in there:
This is really annoying, and ruins a lot of the enjoyment of XBMC on this machine.
Anyone got any ideas I can try, or perhaps even a solution?
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT="10"
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash vga=792,791,773,789,788,771,786,785,769 xbmc=autostart,nodiskmount,setvolume loglevel=0 noredir usbcore.autosuspend=-1"
GRUB_CMDLINE_LINUX=""
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entrys
#GRUB_DISABLE_LINUX_RECOVERY="true"
