Full Version: More Scan issues
karmic, minimal install, xbmc 9.11 installed via xci script(not built from svn, so i assume from repos?)
zotac ion
I have my video and music folders set to scan via a remote button. Music scans fine, movies was scanning fine, but I noticed today, even though I had new tv show content, that tvshows was not scanning correctly.
The
"preparing" popup came up, it sat there for a bit, and then went away, with no new content found. When I manually went to the tv show directory that had new contect, I set that to scan, and again, no new content was found.
Finally, I went to the new files, and then they were added to the library.
what gives? Is there an easy fix or should i just re-add the sources, and rescan everything? I'm hoping for a non-rescan as there is a fair bit of content to scan.
