Full Version: Play All / Shuffle options
I recently finished putting xbmc on my old xbox. I can access my music library on my laptop through up uPNP as is. However, the only way I can find to "play all" is to select the folder and hit play. It searches every single sub directory then...
I am assuming the problem is in my library organization... It was set up by iTunes long ago and is all in sub directories. If I organize my music folder different will the searching run smoother?
Also... Any way to use a shuffle option? I couldn't find it on xbmc for windows either.
*EDIT: Upon looking up after this post, I found the shuffle option. Doh. Still interested to know if changing the organization will help.*
Using Play on a folder recursively traverses the filesystem, adding everything to a play list. If you scan your music into the library, you can use Party Mode which is what I think you're really looking for.
http://wiki.xbmc.org/index.php?title=Mus...Party_Mode
