I have successfully installed XBMC w/Ubuntu on my Revo 1600 using
THIS tutorial. However when I play a 720 file, (mkv or mp4) I still get a video judder. I have also tried doing a custom xorg file using
this tutorial. Any ideas on what else I could try? I do not know how to get the logfile to post it, but I will look on how to do it so I can post it.
When you press the "o" key during playback to see the codec info, does it say VDPAU somewhere?
yes it does. dc:ff-h264_vdpau
With vdpau and a proper xorg.conf it should run smoothly... Maybe somebody else can give some advice here.
Could you upload a video sample that doesn't play on your system?
My xorg look like this.
Section "Device"
Identifier "nvidia"
Driver "nvidia"
Option "NoLogo" "true"
Option "DynamicTwinView" "false"
Option "FlatPanelProperties" "Scaling = Native"
Option "ModeValidation" "NoVesaModes, NoXServerModes, NoVertRefreshCheck, NoH$
Option "UseDisplayDevice" "DFP-1"
Option "ModeDebug" "true"
Option "HWCursor" "false"
EndSection
Section "Screen"
Identifier "screen"
Device "nvidia"
SubSection "Display"
Modes "1920x1080_60_0" "1920x1080_24"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "false"
EndSection
# dePool for SAMSUNG (DFP-0) ---
# lect" : 1920 x 1080 @ 60.0 Hz
# : 1920 x 1080 @ 60.0 Hz
# " : 1920 x 1080 @ 59.94/60 Hz (CEA-861B Format 16)
# : 1920 x 1080 @ 29.97/30 Hz (CEA-861B Format 34)
# : 1920 x 1080 @ 23.97/24 Hz (CEA-861B Format 32)
# : 1920 x 1080 @ 59.94/60 Hz (CEA-861B Format 5)
# : 1680 x 1050 @ 60.0 Hz
# : 1600 x 1200 @ 60.0 Hz
# : 1440 x 900 @ 75.0 Hz
# : 1440 x 900 @ 59.9 Hz
# : 1360 x 768 @ 60.0 Hz
# : 1280 x 1024 @ 75.0 Hz
# : 1280 x 1024 @ 60.0 Hz
# : 1280 x 960 @ 60.0 Hz
# : 1280 x 800 @ 59.8 Hz
hottech956 Wrote:here is my log
You need to turn on debug logging and restart xbmc to get a debug log.
Here is my
DEBUG log with it enabled
I upgraded from Jaunty to karmic, I used
THIS to install XBMC and config the xorg file. I still get a judder on the videos. When I play a video and press "o" I do see "dc:ff-h264 ". I have the 190nvidia drivers.What else could I do to address the judder?
Do you run XBMC in Gnome or do you boot directly into XBMC.
I have a REVO r3610, and when i run xbmc from Gnome do it lag like hell, but it runs smoot if i run xbmc as my x session directly.
it boots directly into XBMC
Would setting the GPU to 512mb make a difference?
