I'm using the latest SVN of XBMC and Transparency! - as of April 23rd. I cleared my library and rediscovered my movies, only to notice that the Trailer icon doesn't show up any more (using Fanart). I also notice that you can't go into settings from within the 'set content' menu anymore. I believe that is where the 'download tralers from dtrailer.com' option was.
am I missing something?
both things work fine on my end (xbmc r29489).
maybe the trailer icon is missing because the scraper didn't fetch trailers when you added your movies to the library?
check if you can access scraper settings through:
Settings > Add-ons > Enabled Add-ons > Scraper
other than that, xbmc svn is a bit unstable...so don't break your head over it when things don't work as expected. ;-)
thanks for the reply...
I'm at xbmc 28256 (highest allowed by Launcher) and Transparency! SVN ~r302 (can't remember). I can click on Add-ons but it doesn't go anywhere from there. So I guess thats my problem. Thanks anyways.
