Simple but powerful iPhone remote app released yesterday:
http://itunes.apple.com/se/app/plexures/...86486?mt=8
Lately I've been trying to learn how to develop applications for iPhone, and started on a remote control for XBMC. I wanted a simple app which gave me full control and is pleased with the result so why not release it on the AppStore...
I hope you'll like it...
Version 1.2 with retina display graphics is now available on appstore. Also added iAds.
The app is still free, so try it out and let me know if there are any issues.
Thanks, seems a very elegant remote. I'll definitely check it out.
I just gave this a go with Dharma beta1, and the only control that seems to work is down. The concept is really cool though, would probably pay for it if it worked.
Version 1.3.1 is now available on the AppStore and includes volume control and tweaks to work better with XBMC. It's free, so check it out...
The simpliest and best remote out there.
If I can suggest you two more features you can implement I would say:
- On-Screen keybord
- A gesture (may be diagonal swipe) to trigger information directly
Excellent job, really
Nice app. Extra points for keeping it free.
hi Steven,
i just started using xbmc and wanted a remote, i downloaded plexures. its great, but how do i start xbmc using remote? thats the biggest let down.
and also touch can be tweaked so that continous swipe will move the controls on the items on the player screen continously, currently each swipe is one left or one right. its should be continous. i mean, thats how the interface of iphone normally works.
anyway, great work and big thanks making the life a bit more easier.
