2010-04-26, 01:16
Real quick background. I don't use a media manager for TV shows, just make sure the episodes are properly named and rely on the internal scraper. With one exception. I have home movies in my library as a custom TV show. I have them in a "Home Movies" subdirectory with a tvshow.nfo file. In addition, I have the video files each with its own nfo and tbn. The directory looks like this:
You get the idea. When I run the scanner, it adds all the videos perfectly.
Now here's the problem. Occasionally I add more videos. When I do this, the scanner adds the new videos, then re-adds all the existing ones so I end up with duplicates. This happens every time the scanner is run. So the first videos I added are in the library 6 or 7 times each.
I can resolve this by deleting the video source and re-adding it. But the next time I run the scanner, the duplicates start piling up again.
Is this a bug or do I have something wrong? How can I prevent the scanner from re-adding "episodes" that already exist?
Thanks!!
-rw-r--r-- 1 theophile theophile 37055769 2009-09-14 13:43 2009-01-11_17:31.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:41 2009-01-11_17:31.nfo
-rw-r--r-- 1 theophile theophile 54550 2009-09-14 13:43 2009-01-11_17:31.tbn
-rw-r--r-- 1 theophile theophile 125008006 2009-09-14 13:45 2009-01-11_18:11.mkv
-rw-r--r-- 1 theophile theophile 1553 2009-09-14 13:47 2009-01-11_18:11.nfo
-rw-r--r-- 1 theophile theophile 57552 2009-09-14 13:38 2009-01-11_18:11.tbn
-rw-r--r-- 1 theophile theophile 16273772 2009-09-14 13:47 2009-01-12_11:31.mkv
-rw-r--r-- 1 theophile theophile 1560 2009-09-14 13:41 2009-01-12_11:31.nfo
-rw-r--r-- 1 theophile theophile 33314 2009-09-14 13:39 2009-01-12_11:31.tbn
-rw-r--r-- 1 theophile theophile 31685067 2009-09-14 13:45 2009-01-12_17:14.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:39 2009-01-12_17:14.nfo
-rw-r--r-- 1 theophile theophile 42627 2009-09-14 13:39 2009-01-12_17:14.tbn
-rw-r--r-- 1 theophile theophile 25134691 2009-09-14 13:46 2009-01-15_07:53.mkv
-rw-r--r-- 1 theophile theophile 1549 2009-09-14 13:40 2009-01-15_07:53.nfo
-rw-r--r-- 1 theophile theophile 33724 2009-09-14 13:46 2009-01-15_07:53.tbn
-rw-r--r-- 1 theophile theophile 146570153 2009-09-14 13:39 2009-01-15_14:59.mkv
-rw-r--r-- 1 theophile theophile 1553 2009-09-14 13:39 2009-01-15_14:59.nfo
-rw-r--r-- 1 theophile theophile 59944 2009-09-14 13:39 2009-01-15_14:59.tbn
-rw-r--r-- 1 theophile theophile 36854700 2009-09-14 13:38 2009-01-22_23:42.mkv
-rw-r--r-- 1 theophile theophile 1554 2009-09-14 13:41 2009-01-22_23:42.nfo
-rw-r--r-- 1 theophile theophile 41079 2009-09-14 13:45 2009-01-22_23:42.tbn
-rw-r--r-- 1 theophile theophile 84859982 2009-09-14 13:41 2009-01-23_19:50.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:40 2009-01-23_19:50.nfo
-rw-r--r-- 1 theophile theophile 45018 2009-09-14 13:46 2009-01-23_19:50.tbn
-rw-r--r-- 1 theophile theophile 43452957 2009-09-14 13:46 2009-01-26_16:46.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:38 2009-01-26_16:46.nfo
-rw-r--r-- 1 theophile theophile 57605 2009-09-14 13:38 2009-01-26_16:46.tbn
-rw-r--r-- 1 theophile theophile 63223412 2009-09-14 13:39 2009-01-28_19:33.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:47 2009-01-28_19:33.nfo
-rw-r--r-- 1 theophile theophile 49150 2009-09-14 13:40 2009-01-28_19:33.tbn
-rw-r--r-- 1 theophile theophile 44870328 2009-09-14 13:41 2009-01-29_17:28.mkv
-rw-r--r-- 1 theophile theophile 1552 2009-09-14 13:39 2009-01-29_17:28.nfo
-rw-r--r-- 1 theophile theophile 55158 2009-09-14 13:39 2009-01-29_17:28.tbn
-rw-r--r-- 1 theophile theophile 773496 2009-09-14 13:47 2009-01-31_17:09.mkv
-rw-r--r-- 1 theophile theophile 384 2009-09-14 13:43 2009-01-31_17:09.nfo
-rw-r--r-- 1 theophile theophile 42860 2009-09-14 13:46 2009-01-31_17:09.tbn
Thanks!!
