Full Version: addding weather.com plus plugin to transparency 1.0?
hi guys,
is there an easy way to enable the weather.com plus plugin for transparency 1.0? i added the includes_weather.xml file but it didn't appear to change anything when i selected the plugin in the weather settings.
i'm using a modified 1.0 skin so switching to 2.11 isn't really an option.
thanks...
you'll also need to update MyWeather.xml,
but if you do, it could also break the skin...i don't know.
hmmm, updating the myweather.xml file with the one from 2.11 resulted in nothing showing up when selecting weather, regardless of whether you had the plugin turned on or not.
