2010-04-28, 11:18
A problem nagging me recently is that I can connect from my PC to my ATV with PuTTY but not WinSCP.
My specs on the ATV side:
Appletv os 3.0.2
Launcher 3.2.3
Xbmc pre-10.5 r28256 (march 1, 2010)
Os Darwin 8.8.2
On the PC side:
Winscp 4.2.6
Putty 0.60
Win7
So PuTTY works fine but the WinSCP log says
Is it because I'm using the svn version (which I'm using because I do have a Crystal HD card and make use of it)? The fact that PuTTY works tells me there's nothing wrong with the network...
Any hint appreciated.
Appletv os 3.0.2
Launcher 3.2.3
Os Darwin 8.8.2
On the PC side:
Winscp 4.2.6
Putty 0.60
Win7
. 2010-04-27 21:04:12.597 Looking up host "appletv.local"
. 2010-04-27 21:04:14.858 Connecting to 192.168.0.11 port 22
. 2010-04-27 21:04:15.863 Failed to connect to 192.168.0.11: Network error: Connection refused
