Full Version: Cannot enable HTTP server in Fedora 12 (no options present)
I cannot seem to enable the HTTP server to for the Web Gui and HTTP-API on my box.
I am running Fedora 13 Beta, with an xbmc based on the 9.11 (r26017) release.
When I go to Settings->Network->Services there is no option for setting HTTP access.
I also installed the Fedora 12 version (same revision) and the problem is the same
Is there a special config file flag I need to toggle or something?
Please check with the Fedora folks. I believe they may have ripped out the webserver due to gpl issues.
TheUni
Thanks,
It is indeed disabled from Fedora. Which is strange since it is actually in the RPMFusion repo.
The next version should be free of GPL issues so next one should have it enabled hopefully
