Full Version: Asrock 330HT remote on Windows XP
Hi folks,
i'm having difficulties with 330HT's remote (which should be MCE compatible) under windows xp. Some buttons are not working and others are not working properly. Does anyone have some experience with this combination?
Thank you very much for any help!
jhsrennie Wrote:Have you looked at http://wiki.xbmc.org/index.php?title=Usi...in_Windows
JR
Yes, but that registry key doesn't exist on my asrock.
Yes, but that registry key doesn't exist after drivers installation.
I have found some solution for Media Portal - is there any way to make it work on XBMC?
