2010-04-29, 10:01
Yesterday I tried to get the above combination to work. But failed.
This works good for xbmc live 9.11 v14:
I cant get the above working on lucid (clean ubuntu install + xbmc). For some reason the lirc service cant start (maybe due to driver issues?)
Anyone that tried to get the Asrock remote working on lucid yet?
Tonight I will add the error message. Any logs I should check specifically?
EDIT:
Also tried the 1.04 driver from the Asrock website (.deb file is inclued for 9.10, so maybe I need to use the source?) Followed the steps from the included pdf document. Lirc wont start
EDIT2:
Made a support request at Asrock. No luck sofar. The Q/A below:
Q:In the download section of the IOn 300HT there is a driver for the for the remote. Made for Ubuntu 9.10. This driver wont work with Ubuntu 10.04 Lucid lynx. LIRC wont start with it.
Can you make a new .deb file for Ubuntu 10.04 Lucid Lynx?
A:Thank you for contacting ASRock.
For the MCE remote control, please kindly use the Ubuntu 9.10 version first.
sudo –s
apt-get install wget
wget http://tinyurl.com/cir-driver-ion330ht (this is the 1.01 driver from Asrock)
dpkg -i ir-driver-ion330ht.deb
reboot
EDIT:
EDIT2:
