Full Version: XBOX Desktop Crashed!
I couldn't download the TH3C version of XBMC from http://t3ch.yi.se/ because the links weren't working on the website.
I successfully installed another version I found on the web (XBMC_Xbox_29504.zip) to my XBOX 1.1, following instructions here:
http://www.productwiki.com/microsoft-xbo...nutes.html
Finding the t3ch site working again, I decided to upgrade to: XBMC-9.04.1-FIXED-BABYLON-T3CH, the readme said:
"Upgrade: Backup the >>XBMC/UserData<< folder. Transfer >>whole<< XBMC folder to Xbox. Overwrite >>UserData<< folder with your backed up copy.Upgrade: Backup the >>XBMC/UserData<< folder. Transfer >>whole<< XBMC folder to Xbox. Overwrite >>UserData<< folder with your backed up copy"
I ftp'd into the XBOX & copied the files across, when prompted to overwrite I said yes. Halfway through, the transfer froze & I lost ftp connection to the XBOX. I can still play games but when I boot without a game disk, the XBOX welcome screen comes up then freezes on the XBMC splash screen & I can go no further.
The XBOX OS files are backed up on my PC, according to advice on the web I can rebuild the XBOX hard drive by installing Slayers Evox Auto Installer 2.6, from a CD. Do I have to take that step or is there another option? If I have to use Slayers Evox, is 2.6 the right version or do I install a more recent one? :confused2:
