Full Version: TV Show Library View
Have to say great work on this skin - my chosen one for the lounge set up!
Have got one problem though - I've added a couple of TV Shows to my Network drive which show up great in Confluence on my iMac, however, using this skin on my Acer Aspire Revo causes an issue.
In file view the shows seem fine, however, in library view one of the shows titles is just replaced with a string of text, the other is fine, but each show that there are no episodes??
I'm using the same scraper on both machines so wondered why its running so well in Confluence but not on this one? I'm running XBMC Live 9.11 and 2.11 of the Skin?
did you also check things in Confluence on your Acer Aspire Revo?
if it's really a Transparency! only issue, please post a screenshot.
cheers. :-)
Sorry - should have done that first really!
Tried Confluence on the Acer and TV Shows weren't showing either - decided to delete the source and start again. Everything showed up fine then.
Switched back to Transparency, rebooted and everything is fine - loving the skin (only had XBMC for a week or so - might explain the noobness!!)
Sorry to have bothered you Ronie - keep up the great work. Big Grin
