The accented character issue is not fixed *yet*. I ended up going away this past weekend so it didn't get fixed. It's about 80% coded up so it will definitely be fixed this week.
travisbell Wrote:The accented character issue is not fixed *yet*. I ended up going away this past weekend so it didn't get fixed. It's about 80% coded up so it will definitely be fixed this week.
I m having similar issues but my movies do not have accent but thumb and fan art fails to come in correctly (the movie info does show so I know it's just the art that isn't working). Is this a known issue as well and I just need to sit tight?
As far as I know everything is working as the XML was changed back to the proper order that XBMC expects.
The only issue I am aware of is the accented character issue.
I just deployed the fix for the accented character issue. Please give it 24 hours (to make sure nothing is cached any longer) and things should start working.
Travis, I'm still not getting fanart for movies with accents or other unusual characters. Here is pastebin from Amelie:
http://pastebin.com/3pRQgwyR
how can I confirm which API method is being use?
Thanks for you help
@pork: Make sure you refresh the movie in question.
I just tried refreshing from the Videos section rather than my Movie library and it worked. Not sure what the difference is but refreshing from within Movies didn't work.
Same here: some of the accented movie titles get fanart now, after refreshing in library, but not all. Weird part is, some don't even have accented or unusual characters:
¡Three Amigos! (granted there's an upsidedown exclamation mark):
Gridlock'd (an apostrophe, but other movies that have one do work):
The Woodsman and Bernie (nothing unusual there!):
I know for a fact these all had fanart before the moviedb changes that inspired this little thread
Debug log needed? And if so, what do I need to do in XBMC to be helpful?
The issue with those movies is slightly different. It's fallout from movies whose name changed before I applied the fix. There's a thread on the TMDb forums about those movies, if you find more just let me know but for now, I've applied the fix for the ones mentioned above (remember, 24 hours or so until the API will update).
ok. i've seen many more of these. those were just a couple i could remember on top of my head.
cant seem to find the thread tho; can you link it?
travisbell Wrote:There's a thread on the TMDb forums about those movies, if you find more just let me know but for now, I've applied the fix for the ones mentioned above (remember, 24 hours or so until the API will update).
Well,
Bernie,
Gridlock'd and
The Woodsman still don't work for me, even after refresh.
Three Amigos does now.
ventech Wrote:cant seem to find the thread tho; can you link it?
Same here..
Anyone know where it is?
