2010-05-01, 10:22
Hi all.
This is my first post here as a new user. So please be gentle.
I have been using the stable 9.11 release of xbmc live on a Mini-itx ION 330 motherboard for some time. And thought that I would like to experiment with the latest SVN builds.
Last night I re-installed xbmc using the XCI project script, on top of a minimal ubuntu karmic installation. The installation went very well with no problems.
I have been using an MCE remote control which also seems to work right of the box, as the wiki says.
However I have noticed that as soon as I use the latest SVN. One particular button fails to operate. This is the button mapped in the remote.xml file
called display.
It is mapped as such <display>FullScreen</display> pressing this button has no effect at all. I have not changed or edited the remote.xml files, I simply looked at them to determine how this key is mapped.
If I drop back to the 9.11 release using the XCI script. Then all is well, and this button operates. As soon as I change back to the SVN release, just this one button fails again, all others are fine.
The TAB key on the keyboard is also mapped to "FullScreen" and this function works fine in all releases.
I have tried using a new remote.xml file, and mapping FullScreen to a different button. However, in the SVN release this too fails to work, but is fine in the stable 9.11 release, hence proving that I mapped it correctly.
Not having the Fullscreen function available on the remote means that should a menu button be pressed while playing a movie, there is no way back to the fullscreen movie, without reaching for the keyboard and pressing the TAB key.
The same mapping files, "Keyboard" and "Remote.xml" have been used while testing both SVN and stable releases. So I can confirm there are no errors in these. Since all works fine on 9.11.
Any help would be appreciated.
Pete
called display.
Pete
