Full Version: Blank screen when xbmc is started.
I've done a clean install of Ubuntu 10.04
I'm running a Zotac Nvidia Ion 330 motherbaord with 4Gb ram
Nvidia drivers 195.36.24
I've got the SVN and compiled it. (revision 29717)
xbmc log file: http://ubuntu.pastebin.com/MD2b23Rh
If I start xbmc from a terminal window, all I see is a black screen with the cursor.
To stop it i have to run
killall xbmc.bin
Heres the output from the terminal window:
bill@ion:~$ xbmc
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  53 (X_CreatePixmap)
  Value in failed request:  0x0
  Serial number of failed request:  146
  Current serial number in output stream:  153
/usr/local/bin/xbmc: line 88: 22174 Terminated              /usr/local/share/xbmc/xbmc.bin "$@"
Anyone got any ideas?
*note* The same happens if i use the team-xbmc-svn ppa
If you need more info please ask...
I got the same problem, on a Intel Celeron D 2.40 ghz, asus p4s800-mx se with Sis Integrated Graphic Card.
The XBMC - Live run without a problem, but extremely slow.
*Update*
I've got the latest from the SVN and recompiled
it now *WORKS*
